9,6K
[box_dark]Detalhes Técnicos e Especificações[/box_dark]
Série Z68, com suporte completo para conversão de vídeo 3X mais rápida e gráficos híbridos universais
Especificações
| CPU | Intel® Socket 1155 for 2nd Generation Core™ i7/Core™ i5/Core™ i3 Processors Supports Intel® 32 nm CPU Supports Intel® Turbo Boost Technology 2.0 * Refer to www.asus.com for CPU support list |
| Chipset | Intel® Z68 |
| Memory | 4 x DIMM, Max. 32GB, DDR3 2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 Hz Non-ECC, Un-buffered Memory Dual Channel Memory Architecture Supports Intel® Extreme Memory Profile (XMP) * Hyper DIMM support is subject to the physical characteristics of individual CPUs. * Refer to www.asus.com or user manual for the Memory QVL (Qualified Vendors Lists). * Due to CPU behavior, DDR3 2200/2000/1800 MHz memory module will run at DDR3 2133/1866/1600 MHz frequency as default. |
| Graphic | Integrated Graphics Processor Multi-VGA output support : HDMI/DVI/RGB ports – Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz – Supports DVI with max. resolution 1920 x 1200 @ 60 Hz – Supports RGB with max. resolution 2048 x 1536 @ 75 Hz Maximum shared memory of 1748 MB |
| Multi-GPU Support | Supports NVIDIA® Quad-GPU SLI™ Technology Supports AMD Quad-GPU CrossFireX™ Technology Supports LucidLogix® Virtu™ Technology |
| Expansion Slots | 2 x PCIe 2.0 x16 (x16 or dual x8) 1 x PCIe 2.0 x16 (x4 mode, black) *1 2 x PCIe x1 2 x PCI |
| Storage | Intel® Z68 chipset : 2 x SATA 6Gb/s port(s), gray 4 x SATA 3Gb/s port(s), blue Support Raid 0, 1, 5, 10 Support Intel® Smart Response Technology on 2nd generation Intel® Core™ processor family Marvell® PCIe SATA 6Gb/s controller : *2 2 x SATA 6Gb/s port(s), navy blue JMicron® JMB362 controller : *2 1 x eSATA 3Gb/s port(s), red |
| LAN | Intel® 82579, 1 x Gigabit LAN Controller(s) |
| Bluetooth | Bluetooth V2.1+EDR ASUS BT GO! Utility |
| Audio | Realtek® ALC 892 8-Channel High Definition Audio CODEC – Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking Audio Feature : – Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound – Blu-ray audio layer Content Protection – DTS Surround Sensation UltraPC – Optical S/PDIF out port(s) at back panel |
| IEEE 1394 | VIA® 6308P controller 2 x IEEE 1394a port(s) (2 at mid-board) |
| USB Ports | ASMedia® USB 3.0 controller : 4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board) Intel® Z68 chipset : 12 x USB 2.0 port(s) (6 at back panel, black+red, 6 at mid-board) |
| Overclocking Features | Overclocking Protection : – ASUS C.P.R.(CPU Parameter Recall) |
| Special Features | ASUS Dual Intelligent Processors 2 with DIGI+ VRM : ASUS TPU : – Auto Tuning – TurboV – GPU Boost – TPU switch ASUS EPU : – EPU – EPU switch ASUS Digital Power Design : – Industry leading Digital 16 Phase Power Design (12 -phase for CPU, 4 -phase for iGPU) – ASUS DIGI+ VRM Utility ASUS BT GO! : – Folder Sync – BT Transfer – Shot & Send – BT to Net – Music Player – Personal Manager ASUS BT Turbo Remote : – Exclusive Smartphone Interface supporting iPhone, Android, Windows Mobile, and Symbian systems ASUS Exclusive Features : – MemOK! – AI Suite II – Ai Charger+ – Anti-Surge – ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface – Disk Unlocker ASUS Quiet Thermal Solution : – Stylish Fanless Design Heat-sink solution – ASUS Fan Xpert ASUS EZ DIY : – ASUS Q-Shield – ASUS O.C. Tuner – ASUS CrashFree BIOS 3 – ASUS EZ Flash 2 ASUS Q-Design : – ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED) – ASUS Q-Slot – ASUS Q-DIMM – ASUS Q-Connector |
| Back I/O Ports | 1 x Bluetooth module(s) 1 x DVI 1 x D-Sub 1 x HDMI 1 x eSATA 3Gb/s 1 x LAN (RJ45) port(s) 2 x USB 3.0 6 x USB 2.0 1 x Optical S/PDIF out 6 x Audio jack(s) |
| Internal I/O Ports | 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, moss green) 3 x USB 2.0 connector(s) support(s) additional 6 USB 2.0 port(s) 4 x SATA 6Gb/s connector(s) 4 x SATA 3Gb/s connector(s) 2 x IEEE 1394a connector(s) 2 x CPU Fan connector(s) (4 -pin) 2 x Chassis Fan connector(s) (1 x 4 -pin, 1 x 3 -pin) 2 x Power Fan connector(s) (3 -pin) 1 x S/PDIF out header(s) 1 x 24-pin EATX Power connector(s) 1 x 8-pin ATX 12V Power connector(s) 1 x Front panel audio connector(s) (AAFP) 1 x System panel(s) (Q-Connector) 1 x MemOK! button(s) 1 x TPU switch(es) 1 x EPU switch(es) |
| Accessories | User’s manual ASUS Q-Shield 2 x SATA 3Gb/s cable(s) 2 x SATA 6Gb/s cable(s) 1 x SLI bridge(s) 1 x Q-connector(s) (2 in 1) 1 x ASUS USB 3.0 Bracket(s) |
| BIOS | 64 Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen Function |
| Manageability | WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE |
| Support Disc | Drivers ASUS Utilities ASUS Update Anti-virus software (OEM version) |
| Form Factor | ATX Form Factor 12 inch x 9.6 inch ( 30.5 cm x 24.4 cm ) |
| Note | *1: The PCIe x16_3 slot shares bandwidth with PCIe x1_1 slot, PCIe x1_2 slot, USB3_34 and eSATA. The PCIe x16_3 default setting is in x1 mode. *2: These SATA ports are for data hard drivers only. ATAPI devices are not supported. |
[button link=”https://overbr.com.br/review-asus-p8z68-v-pro-para-quem-sabe-o-que-quer/4″ variation=”darkgrey”]Anterior[/button] [button link=”https://overbr.com.br/review-asus-p8z68-v-pro-para-quem-sabe-o-que-quer/6″ variation=”darkgrey”]Próxima[/button]
2 comentários
Opa,bela analise.uma duvida.meu pai tem um pc de escritorio com um celeron dual core,775,mas ddr2.queria mudar pra ddr3.sera que ela funciona com o celeron?vlw.
Belo review Xandelly! Extremamente bem ilustrado ein? É foto que não acaba mais hehehe
Gostei da foto da chamada, ficou bonito o F1 nessa mobo :D
