[box_dark]MODELOS TESTADOS[/box_dark]
Koolance FAN-12025HBK high quality, dual ball-bearing fan.
- Dimensions: 120x120x25mm
- Type: Dual Ball-Bearing
- Connector: 3-pin (3-wire with tachometer)
- Rated Voltage: 12VDC
- Current: 0.28A
- Speed: 2600RPM (max)
- Static Pressure: 5.4mm-H2O
- Airflow: 107.6CFM (max)
- Noise: 32.80dBA (max)
Scythe “SLIP STREAM” SY1225SL12SH Case Fan
- Bearing Type:Sleeve
- RPM:1900 ±10% RPM
- Air Flow:110.31 CFM
- Noise Level:37.00 dBA
- Power Connector:3-pin (3-pin to 4pin adapter included)
- Color:Black
- Compatibility:Case
- Dimensions:120 x 120 x 25mm
Titan modelo TFD-12025GT12Z (RB)
- Fan Dimension 120 x 120 x 25 mm
- Rated Voltage 12 V DC
- Rated Current 0.05 A
- Power Consumption 0.6 W
- Rated Speed 800 ± 10%RPM
- Airflow 31.66 CFM
- Static Pressure 0.07 InchH₂O
- Noise Leve < 16.1 dBA
- Connector 3-PIN
- Bearing Type Z-AXIS
Enermax T.B.SILENCE w/ Batwing Blades,HALO Frame w/ Punched Air Intake
- Modelo UCTB12
- Dimension: 120w*120h*25
- Bearing type: Twister Bearing
- Frame: carved Halo Frame
- Blades: batwing
- Blades number: 9
- Speed RPM 900 (+-100%)
- AirFlow : 71,54 m3/h
- Static pressure 0.828 mm-h²o
- Noise: 11 dB
- Rated Voltage 12v
Akust Sleeve Bearing Fan – Blue Blades
- Fan speed at 1,200RPM at 24.5dB(A) noise
- Extreme air flow at 2.30mm- H2O
- Unique high quality blue color blade design
- Compatible for Case and CPU Cooling Fan
- 120x120x25mm
- Manufactured by: Akust Technology
Cooler Master High Performance R4 Series – Dark Smoke Case Fan – Sleeved
- AirFlow 69CFM (maximum RPM)
- 19 dB-A silent application for CPU cooling.
- RoHS compliance for protecting the environment
- Recommended for V10, V8, Hyper 212, Hyper Z600, Gemini, Cosmos, Cosmos S, HAF 932, HAF 922, CM Storm Scout and Sniper.
- Current Ampere 0.35A
- Voltage 12v
- Air Pressure 3.04 mmH2O
- Bearing Type: Long Life sleeve
Yate Loon High Speed Silent Case Fan – D12SH-12 – Sleeved
- Model: D12SH-12
- Fan Frame: Current version is CLOSED CHASSIS not like picture shows.
- Air Flow: 88 CFM
- Fan Speed: 2200 RPM
- Noise Level: 40 dBA
- Current: 0.30 Amps
- Fan Size: 120x120x25 MM
- Connector: Includes a 3-pin motherboard power / RPM connector and a 4-pin standard power connector
- Noise, tolerable 40 dB(A)
- High airflow level, 88 CFM
- 3-pin motherboard connector / RPM monitoring
- Two 4-pin connectors (male and female)
Koolance Fan 12038HBK
- Dimensions: 120x120x38mm
- Current: 0.75A
- Static Pressure: 6.333mm-H2O
- Airflow: 116.101CFM (max)
- Noise: 39.00dBA (max)
Yate Loon CLEAR High Speed Silent Case Fan with Red LED
- D12SH-124R – Sleeved
- Model: D12SH-124R
- Air Flow: 88 CFM
Fan ADDA AD1212LB-A71GL
- model AD1212LB-A71GL
- voltage: 12v
- Current 0.15A
- RPM 1800 max (+-100%)
- CFM 71,8
- Static Presure 0.093
- Noise Level: 34,4 dB
Fan MAXPower MPFAN12LT HIGH Performance Leds BLUE
- Marca: Maxpower
- Modelo: MPFAN12LT
- Cor: Cristal Transparente
- Dimensão: 120x120x25mm
- Velocidade: 1200+-10% RPM
- Ruído: 26dBA
- Fluxo de Ar: 65,51 CFM
- Rolamento: Sleeve Metal Bearing
- Número de LEDS: 4 LED azuis
- Conector: 3 pinos (placa mãe)
- Fan MTBF: 30.000 hs
Evercool 140mm Evergreen Silence Fan (x Low Speed)
- Overall: 135x135x25mm
- model EC-EGF-N12
- Bearing type: Ever lubricate bearing type
- Life time: 40000 hrs at 25c degree
- Rated speed: 1200 +- 10% rpm
- Noise Level: 24dB
Yate Loon 120mm High Speed Fan: D12SH-12(F)
- Model: D12SH-12 (F)
- OperatingVoltageRange: 6.5 ~ 13.8V
- Rated Current: 0.30A
- Thickness: 25mm
- Rated Speed: 2200 RPM ± 10%
- Max Air Flow: +- 70 CFM
- Sound Level: 40 dB
- Connector: 2 pin (model F)
7 comentários
Eu to aguardando a chegada de 3 Koolance FAN-12038HBK-184 que ganhei de um amigo, pretendo usar 2 delas no meu antec 620
Parabéns pelo review, ficou muito claro e informativo.
Eu queria saber mais sobre esses coolers Nideo BETA. Seriam aqueles Nidec de aplicação em servidores? Onde posso encontrar esses modelos à venda. Eu notei que em 12V eles são bastante silenciosos e mesmo assim o CFM deles é substancialmente maior.
Eu uso 6 Evercool Aero no meu radiador de 360mm, eles são bons e em 5V são bastante silenciosos, mas o PC parece que vai decolar se eu coloco em 12V, o barulho chega a incomodar um bocado e estava pensando em trocar por algo mais silencioso mas com CFM maior, mesmo que tenha que pagar mais caro por isso.
Agradeço desde já a atenção da equipe e o esforço e a preocupação em manter o público entusiasta brasileiro sempre atualizado.
Olá irmão, infelizmente por um equívoco na elaboração dos gráficos finais o nome acabou saindo NIDEO enquanto o correto é NIDEC, e sim elas são utilizadas nos servidores DELL e outros modelos Optimus, seu preço de mercado algo em torno de 100 reais, oferece um fluxo final de 230 CFM. Mas quando utilizadas em baixa rotação o fluxo é enorme e o ruído final é satisfatório. Não sei te informar onde vende.
Abraços e vamos que vamos
Parabéns o obrigado pelos testes Xandelly. Nada melhor do que se informar antes de sair comprando qualquer coisa.
O melhor agradecimento é a sua participação. Quem tem realmente a agradecer algo por aqui, este sou EU !
Estamos tendo uma certa dificuldade de elaborar os reviews devido ao acúmulo na lista de espera dos testes, e isto acabou causando uma certa lentidão na publicação de todos os testes. Existe ainda a parte 2 deste review, com outras 17 FANS de mercado, esperamos em breve finalizar e levar ao conhecimento de todos.
Um grande abraço, e no que precisar, estamos aqui !
Tenho 4 Koolance FAN-12025HBK no meu radiador de 480mm e eles seguram de boa :D
Mto forte esses fans !!
Olá KEN HUANG,
grato por sua participação, sinta-se em casa. Sim, estes FANs da Koolance além de ótimos são extremamente fortes com ótima qualidade, a única dificuldade e realmente chato é achá-los para venda dentro do Brasil. Interessante seu WC Eim !! Que tal partilhar das fotos? Abraços
